Dell e6410 bios password
    Re: Dell e6410 bios password
    dear friends,
    help me for dell latitude e6410 bios password.
    Service tag: 1Q7R1M1
    system #1Q7R1M1-2A7B
    thanks,
    masud.
      Originally posted by masud View Post
      dear friends,
      thanks,
      masud.
      Hello Masud
      Your Admin password is, vjjrgfBB565J12T9
      Entered on a Qwerty keyboard
      It is Case sensitive
      Ctrl+Enter
      Good luck
        not working.
        this is dell latitude i5 E6410 laptop.
        plz help.
          hi there,
          I have a Latitude e6410 with administrator password locked. Need your help to unlock it. My system is: 6TRKQM1-2A7B. Many thanks!
            Hello Everyone:
            please help me remove pasword bios.
            system number :9KLVQM1-2A7B [Dell Latitude Laptop: E6410].
            THANKS FOR HELP
              Please help me "Remove BIOS Password".
              System Number: 35GXTM1-2A7B
              SERVICE TAG: 35GXTM1
              DELL LATITUDE LAPTOP: E6410
              THANKS FOR HELP
                Originally posted by boctmy View Post
                hi there,
                6TRKQM1-2A7B = ykFyfQ1e2vpNgr43
                  Originally posted by mdavis800@gmail.com View Post
                  Hello Everyone:
                  THANKS FOR HELP
                  9KLVQM1-2A7B = ots5kgAHz6jwKbfg
                  35GXTM1-2A7B = 6j6DS4zp0tBT6Z4e
                  The above is a zero not an o
                    Thanks for above input
                    [35GXTM1-2A7B = 6j6DS4zp0tBT6Z4e
                    The above is a zero not an o].
                    Unfortunately, above password doesn't work.
                    Do you have any other alternate password.
                    I would appreciate your response.
                    Thanks!
                      Thanks!
                      That should work, make sure you enter it as listed because it is case sensitive. Also some systems require you to hold the ctrl key when you press enter and I have heard that you have to press enter twice for some.
                        Thanks so much.
                        Greatly appreciate your support.
                        New Status:-
                        1. BIOS Password is removed successfully.
                        2. ATA (Hard Drive is set to SATA Mode) in System Information
                        3. Windows 7 Ultimate is successfully Installed.
                        Have A Wonderful Time Ahead.
                          Hello
                          i have a dell latitude e6410
                          Please help me my english is poower
                          My problem is when I turn on my laptop it asks for a password bios password and a message is displayed with code # 4RG15Q1-1F5A
                          I want you gave me the password for my bios please
                          thank you very much
                          my keyboard is QWERTZU
                            Hello Im New Here, y try to reset using Cmos Battery, but not work
                            Can Helpme with this SERVICE TAG #GMYX4Q1-1F5A thanks for you cooperation
                              Solved with this Code 9231fbq34Awq7Rz0
                                @monedadeoro
                                can you tell us how you got the password ?
                                did you have to pay for it ?
                                  Maybe somebody can give me a admin password for bios
                                  98QLYN1-1F5A
                                  br
                                    Hello I need bios password for
                                    Dell latitude e5400
                                    Service TAG = GHJRJ4J-1F5A
                                    Thank you
                                      Hallo, please help me. My service tag is D4310P1-1F5A Is here anybody to send me bios password ?
                                        Try this one ots5kgAHz6jwKbfg
                                        Dell by hdd serial number new
                                        9bz7gyqt
                                        v6qedqqe
                                        Ah4rgzC1t6065wiB
                                        tbuxc4eo
                                          Laptop Bios Passwords
                                          Mostly all laptops can be unlocked by master password which unique for every laptop
                                          Mostly all desktops may be unlocked by removing coin battery or by special jumper.
                                          Laptops have EEPROM which cannot be cleared by removing battery.
                                          Many customers forgot their passwords, sometimes it laptops from ex-employee or purchased on garage sale.
                                          Many computer models can be unlocked by master password which depend from password, serial number or even random generated after special procedure.
                                          Master passwords can be generated by special tools, mostly all are not worldwide available, very few persons have it.
                                          [5-digit code]
                                          More often case is computer bios by Phoenix, which use 5-digit code after 3 unsuccessful tries to generate master password. Bios from Phoenix used by practically all brands with some modifications in the code calculation. For HP Omnibook and HP Pavilion to get 5-digit code need to press F2 F12 at password prompt.
                                          For example usual hash code: [12345] password: 1134334
                                          HP models hash code: [12345] password: 1221196
                                          [DELL service tag]
                                          Dell use service tag to generate master password. Usually it ended with —595B.
                                          Some models used modified algorithm for —A95B service tag which sometimes differ from —595B
                                          Obsolete models may use —D35B tag for that exist freeware utility
                                          Inspiron 700m and 710m use only service tag without suffix like —595B
                                          Very old models have special master passwords but such models are junk now.
                                          Master password generate separately for BIOS and HDD, because for HDD used its 11-letters serial number.
                                          For old Dell laptops exist so called Paperclip method, it works but dangerous, many laptops are bricked now
                                          For example:
                                          service tag: 1234567—595B password: 46rg65ky
                                          service tag: 1111111-A95B password: 2qhuvn1b
                                          service tag: 1234567-D35B password: 5tc8q9re
                                          HDD serial number: 123456789AB-595B password: 76sf9hsl
                                          HDD serial number: 123456789AB-A95B password: 5m8oalqm
                                          Inspiron 700m: [1234567] password: 37897101
                                          [SONY]
                                          Sony PCG series can be unlocked by last 7 digit from serial number
                                          Sony VGN-A series after 3 tries it generate random xxxx — 4-hex code
                                          Sony VGN other series after 3 wrong tries it generate random 5x4 code, do not turn off laptop until get master password
                                          For example: Sony VAIO VGN-SZ22 [268r-dkxj-38j7—9j2k] password: 33637436
                                          [Fujitsu-Siemens]
                                          This brand use many different algorithms to calculate master password
                                          Main code: xxxx-xxxx-xxxx-xxxx-xxxx 5x4 digit, to get it enter 3 passwords one by one:
                                          3hqgo3
                                          jqw534
                                          0qww294e
                                          Do not enter again passwords until you get master password
                                          Other variants is 5-digit code, 8-digit code, 5x4-hex code, need to know exact model as many models has different calculations.
                                          Some models have PIN-lock panelm which can be unlocked by erasing concerned EEPROM
                                          For example: LifeBook Q2010: 1111—2222—3333—4444—5555 password: 8i4wjlon
                                          For example: Amilo Pro V3205: 12345678 password: 2171081
                                          [Asus]
                                          Asus laptops use current date which show at system start up to generate masterpassword.
                                          For example: 2007—12—31 password: LAOLDOA0
                                          [Acer]
                                          Mostly used Phoenix 5-digit code to get master password, various algorithms
                                          v1 [12345] password: 1134334
                                          v2 [12345] password: B5P1HA7
                                          v3 [12345] password: 1123155
                                          v4 [12345678] password: 03023278
                                          [HP]
                                          HP use classic Phoenix 5-digit code and HP modified 5-digit code
                                          There is also HP-Compaq models, which can be unlocked by manipulations with battery and charger
                                          For example: System Hash Code [12345] password: 1221196
                                          [Samsung]
                                          Samsung use 16-hex code which appeared after 3 unsuccessful tries to restore forgotten password
                                          For example: System Disabled [153E0FC8C7B03144] password: SAMSUNG
                                          [Toshiba]
                                          Old laptops can be unlocked by floppy key disk, LPT key, USB key.
                                          Current models use Challenge method: at password prompt press keys one by one: CTRL, TAB, CTRL, ENTER. Computer will respond with PC Serial number and Challenge code. You have to respond with Response code
                                          Some Toshiba use Phoenix 5-digit code, but it appear for very short time, you have to use camera to catch the code.
                                          Challenge method have at least 3 modifications.
                                          1) for laptops like Qosmio F10, all algorithm located inside BIOS except one calculation on the other side
                                          2) for laptops like Tecra M4, core of algorithm hidden inside of EC/KBC chip with encrypted firmware
                                          3) the same laptops but with corrupted eeprom contents which connected to EC/KBC
