A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
    Re: A guide to fixing/troubleshooting some common plasma TV problems
    All. the. damn. time.
    I may request this thread be locked.
      It should be locked or pruned significantly. If I were something looking at the title of this thread, I would expect one or two posts at most from the author. Not a hodge podge of questions on various TVs.
      However, I know the feeling. Even when I explicitly say don't ask questions in post #1 of a "how to guide", people can't or won't follow instructions.
      --- begin sig file ---
      --- end sig file ---
        Good job Tom!! I needed some basic plasma troubleshooting, and this is greate, thanks a lot.
          i have plasma Panasonic 42inch and i have horizontal line.
          Some help
            The plasma panel is likely bad -- not repairable.
              Hello, I have a Hitachi 42 inch plasmas, model number: HD42S69. I have a 3 inch thick vertical red line, left of center (if your facing the tv) that sporadically appears, but often. I took it to a repair shop. The guy told me that its not the control board and it isn't the display panel, it's a buffer board. He wanted $200 and he said the part is like $60. I figured I can just do it myself, but I don't know where the buffer board he was talking about is? Can you help me locate it? How do I even know what board is causing the issue?
                It's more likely just the connection between the X-buffer board and panel. Start a new thread and provide pictures of inside your set, and you can probably fix it yourself.
                  Here are pics:
                    Here are pics:
                    Another pic:
                      I don't have privileges to start a new thread for some reason.
                      I included two pictures for your review.
                        Where is the x-buffer board on the picture of the rear of the tv I provided?
                          All users have permissions to start threads I thought. I'd rather not clutter up this thread even more (it's getting hard to track replies and individuals), so if you can't create a thread, please contact Topcat (administrator) and ask him why you might not be able to do so.
                            I posted a new thread, thanks.
                              Hello there, just need someone to take a quick glance at the display on this photo to see if this TV is repairable.
                              Philips 42" Plasma - Model 42PF7320A
                              Thanks in advance.
                                Thanks in advance.
                                Yes - bad X-main, replace the X-main. Post a thread if you need more help.
                                  I shall do that. Thank you tom66
                                    Looking at the picture, it also looks like the Y-buffer may be bad, but the X-main is causing the discolouring too.
                                      Tom congrats on your wonderful guide!
                                      I have an LG 42PC1DA and when I turn on the the in the morning (when the tv is cold), the image is distorted and pinkish purple, then in clears up and the image is near perfect.
                                      This is very much like the image you show on the guide for this problem :"The picture is slow to update (motion blur) and has a purple or lilac tinge to it."
                                      I dont own voltage testing equipment. Do you think it is a good idea to just change all the fuses on the zsus board?
                                      Please help.
                                        If the problem gets better over time, it is -unlikely- to be a fuse issue.
                                        It is best to start your own thread and add pictures to it.
                                        A multimeter, essential for all TV repair, is available for under $10 from many good retailers.
                                          thanks tom, I have started a thread. I will add pics tonight.
                                          Any clues based on the symptions described?
                                          What is strange is the image is perfect after about 5 -15 minutes. But when i turn on cold, it is lavalamp like.
