I have a Dell motherboard that has the capacitor plague and 12 caps have obvious signs of failure. The majority of failed caps are the infamous Nichicon variety with a date code: HN0249 (1800uF, 6.3v). Initial symptoms were a couple of thermal event errors followed by the system not booting at all.
I bought a refurbished board (supposedly refurbed by Dell) and noticed that it had the exact same caps as the old board, but since it had a warranty, I thought I'd install it and see what happened. Well, two caps blew immediately on the first boot attempt.
I pulled the PSU and bench tested it with a multimeter and the voltages all were well within tolerances of the pinout schematic. Of course, this was not under load. I can't find an easy way to open the PSU to check for any blown caps inside.
All fans are functioning, although I could not do an RPM test. The case is spotless, in terms of dust and dirt. I re-installed the processor using a good quality thermal paste. Since the refurb blew out so quickly, is it reasonable to suspect something other than bad Nichicons is to blame?
Any insight would be greatly appreciated.
Mario T
Mario T
