Problem with Viewsonic VG920 lcd monitor
    Re: Problem with Viewsonic VG920 lcd monitor
    hi to all
    I too have this card type 715g1492-1
    My problem is: the voltage is 13 volts and oscillates between 12.7 and 13.10
    the 5 volt ranges between 4.65 and 5.10
    all capacitors have been replaced but the problem remains
    can anyone help me
    Thank you
      Originally posted by pippo_one View Post
      hi to all
      can anyone help me
      Thank you
      If you have read the thread you will see it could be the main board however
      we can look at it with you.
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
      Please update your profile with country and mains voltage.
        thank for your repley
        i send the photo, i found in this forum and i have the wiring diagram
        but until now i not solved the problem
        i think my problem is "the voltage is not stable"
          We need to have pictures of YOUR boards - it is no good looking at problems on other boards.
            it's the same board
              Really? - i think one of these components could be faulty
                i know , but which component..... it makes me swing tension
                i have measure with digital tester and i found
                (change values quickly during the measurement)
                ( 5v) from 4,65 to 5,10volts
                ( 12 v) from 12,70 to 13,10 volts
                and i hear a litle tic-tic
                  some one help me
                  thanks
