Problems with Samsung 740N monitors
    Re: Problems with Samsung 740N monitors
    my samsung 740n is dead
      Fuse here;
      Mann-Made Global Warming.
      - Dr Seuss
        Tanks for all the guys here. I got really helpful info here during the DIY for repairing my Samsung 740B.
        Right now, I got my LCD work and go well.
        What I did is:
        a) replaced three 820uf 25v caps beside the transformer
        b) unsoldered the green small 3A fuse beside a 820uf 25v cap, then solder a solid wire into it.(as i don't have any alternation one in hand, but it is risky)
        As a result, bad caps always play the key role and induce the fuse burnt.
        New discovery: OEM used the same model power board in IBM L171p LCD, which means samsung made PBD for IBM monitor as well.
          What I did is:
          Hopefully, you'll reconsider and use a real fuse versus a plain wire. Fuses are used for a reason.
            thanks for all guys here
            I have SyncMaster 730B, its board model IP-35135B, for few days looking for its schematic
            please if one have service manual for 730B
            i download service manual for 740N and its schematic different and not match.
              Service manual here.
              PlainBill
                Sorry to bother, I'm new to the site
                I hope it helps me find a way to download the file where the site is in Hungarian (translate it to english through google translate) and tried to register but only rejected a joint invitation from someone Active
                I hope that helps me
                Accept my profound thanks and appreciation
                  The site is located in Poland.
                  Menus are in Polish and English.
                  Registration is not required.
                  Steps:
                  1. Click on link.
                  2. Click on blue arrow next to Samsung 730BF. A new page opens.
                  3. Click on Get Manual upper left part of page.
                  PlainBill
                    Hi, PlainBill
                    Thank you for your help and your answer
                      Hi, PlainBill
                      Je vous en prie!
                      PlainBill
                        Samsung LCD 740nw Led flashes and no picture
                        Hello ... The problem I have with my monitor is that when connected to the grid is turned on the power button is blinking and not showing me anything on the screen even in a message that has no connection to the pc. Thanks & Regards .........
                        help
                          help
                          1. Do not post pictures inline. Use 'Manage Attachments' - below the text entry area.
                          2. Do not use pictures you found on the internet. The first one has obviously defective caps. The second shows only a fragment of the power supply.
                          PlainBill
                            hello apologies
                            Some possible solutions
                            where to begin to test
                            all coils are in perfect condition
                            status as verefico (dm0465)???
                            thanks
                              hello apologies
                              thanks
                              Start by replacing all the electrolytic caps except C105? (the big yellow one). At least two of them are defective.
                              PlainBill
                                problem solved
                                capacitors were only 10v/1000 microfariados
                                thanks
                                  Hi everyone!! I have a problem with my Samsung 743NX
                                  https://www.badcaps.net/forum/showthread.php?t=16559
                                  Any suggestions?? Thank you very much!!
                                  Joss.
                                    Joss.
                                    Three suggestions:
                                    1. Stop hijacking threads.
                                    2. Don't double post.
                                    Either of these will cause some people to ignore you.
                                    3. Follow Rtech's advice.
                                    PlainBill
                                      Originally posted by PlainBill View Post
                                      Three suggestions:
                                      PlainBill
                                      Oh i'm so sorry Thanks for the suggestions, I'll do.
                                      Joss.
                                        Hi
                                        I'm new here and I'm looking for a solution for my 740. After I turn on the monitor it only shows the image for 1 second but blue led is on. The problem is that my power board is not exactly the same as posted here, my power board is BIZET-17A, REV:1.0A 2005.1.20 BN44-00123A. Components are not the same, I donĀ“t have mosfet, caps 820, pico fuse... and design is different.
                                        Anybody can help me?
                                        Thanks in advance!
                                          1) 2 seconds to black can be
                                          a) bad caps
                                          b) bad inverter transformer
                                          c) bad ccfl and/or wiring
                                          All are discussed in more detail in posts #13 and #14 at
                                          Also please read misc suggestion #1.
                                          --- begin sig file ---
                                          --- end sig file ---
