The infamous 2 seconds to black
    Re: The infamous 2 seconds to black
    I can read one Q.
    The top line says LT7215H.
    The second says SBL1060CT.
    The other one has absolutely no markings. Could they have been destroyed by heat?I will have to learn up on where to probe them for voltage.
    I assume to test the transformer that all the outputs are + ? So if I probe any of the wires coming out of it and ground I should be good to go, yes?
    P.S. Thanks for taking the time to explain basic things. I am sure that must get old for those who are experienced.
      Originally posted by shimjocky
      I can read one Q.
      Nevermind the explanation.I can explain anything you want or need, even if you think it is a 101 sort of thing. I learned that way, and I can pass that on to the newcomers. Sometimes I post comments or explanations along my posts so people that just browses around and never register to make any question directly, can benefit from the forum.
      I am not that wise as PCBONEZ, Krankshaft, Wizard and many others around here (Toasty has been a great help too), but if in any form I can help, I will.
      Now, back to our patient ....
      The component is a Schottky Barrier (see here ).
      Nevermind the T for now. Look at the picture. Do you have voltage reading in any of those two jumpers, and on the cap in the picture?
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
        I checked both jumpers and both sides of the cap. In all cases i get a spike to less than 1 volt then it drops off to 0.
          I've run out of ideas for now. The voltage that reaches teh inverter area is 12v or more, depending on the number of lamps (I've seen 12,13 & 14 v so far). Check the voltage in the 12 V rail caps (those with 16 or 25v ratings) that you changed. You mentioned that the 12V line fluctuated before. What readings have you now on the 12v line?
          Also, what V do you read on the resistor between the Schottky and a cap?
          at the left):
          Double check for correct orientation of caps and make sure the solder is OK (reflow if necessary). We'll be dealing only with the 12v line only, i guess.
          • GeForce GT1050
            before we go any further I have another silly question for ya. Is it ok to do all this on the bench? That is to say will the power supply work properly without being hooked up to everything?
              Not silly. That is a good question. Some PSUs work on the bench and others need load to work. If it makes you more comfortable, you can hook it up to the rest of the monitor and test. The lamps would not come on until the inverter receives the BL_ON signal, that comes from the Video board. Hook it all together, and see what happens. With the monitor in the ON state, and with signal applied (green led on the front, with VGA cable connected), redo the reads on the jumpers.
              Asking is the way you'll learn, so don't be afraid. Nobody sees you, actually (except maybe the more than 10,000 members, but we don't count ...)
              • GeForce GT1050
                Thanks a bunch eguevarae.
                Gonna call it quits for tonight as I have a bunch of CAD homework to do. Will get the monitor put back together on Friday and proceed with the testing.
                  I'll be waiting.
                  • GeForce GT1050
                    Originally posted by eguevarae
                    Transistors.
                    R = Resistor
                    F = Fuse
                    TH = Thermistor
                    D = Diode
                    Q = Transistor <---------------- I don't know why Q, because as you can see we had a pattern here until mr. Q arrived
                    Because T for transformer was already taken?
                    PlainBill
                      PlainBill
                      T in transformer, TH in Thermistor. It could have been TR.
                      Or, in the case of the C5707, because they fail Quite a lot and are pissing off Quite a big crowd when the Quit working on low Quality designs or implementations? ....MMMMmmmm... I wonder....
                      • GeForce GT1050
                        T was Taken.
                        Mann-Made Global Warming.
                        - Dr Seuss
                          Originally posted by PCBONEZ
                          T was Taken.
                          I guess That answers my Question...
                          • GeForce GT1050
                            See the marked components? those are jumpers. There may be a fuse around that area, as I can't locate any on the other side of the board.
                            Hello Eduardo
                            Those 2 rectangular boxes that are in the Third picture down, by the cap you arrowed, in this link of this thread,
                            https://www.badcaps.net/forum/showpo...09&postcount=4
                            I am 99% sure they are fuses
                              Originally posted by Bobdee
                              Hello Eduardo
                              Hi, Bob.
                              I didn't mark it, it was shimjocky. And I can put the remaining 1%, as they are fuses: 5A 250V.
                              They are similar to this
                              • GeForce GT1050
                                Transistors.
                                R = Resistor
                                F = Fuse
                                TH = Thermistor
                                D = Diode
                                PF = Pico Fuse might be found in those boards.
                                Be a mensch
                                  You're right. I forgot about the picofuses.
                                  • GeForce GT1050
                                    HERE TOASTY
                                    HERE TOASTY
                                    [Self appointed resident spell checker. -> SARSC]
                                    Pico Fuse or picofuse. ??
                                    [I don't really care. I'm just bored.]
                                    - Dr Seuss
                                      HERE TOASTY
                                      HERE TOASTY
                                      Can we settle for PF? less characters and no lousy spaces to mess with.
                                      [I don't really care. It's my third night with insomnia and I'm going insane already ]
                                      • GeForce GT1050
                                        Slam a stiff triple of whatever. (or fourple or fiveple if you drink often)
                                        Before it hits take a hot hot shower.
                                        Whack-off.
                                        And then crash.
                                        - Dr Seuss
                                          Google seem to indicate that Pico Fuse is the most used form, and my real time dictionary in FireFox does not accept picofuse. The general rule in English is not to concatenate words, I believe. We Norwegians, using both languages, has to be on the alert on this, because the general rule in Norwegian is to concatenate such terms.
                                          Be a mensch
