The main 4A fuse was blown when i got this monitor. Changed out the fuse and this is what i see. I checked the fuse on the t-con and it measures 0.3ohm. The main board is full of capxon caps. Can a bad cap cause a display like this or am i looking at a failing lcd panel? I ordered a Peak Atlas 70 ESR meter on monday so when i get it i can check the capacitance and esr of the caps on the main board.
Just seeing if anybody has had any similar situations.
Edit:
I did clean and reconnect the 30 pin cable going from the main board to the screen
Edit:
