Can you show where the cable is coming from? What is the connector number that broke? Is the camera internal or external? The connector that broke how many positions did it have? Does the camera support IEEE 1394 interface?
cable is coming from webcam , internal camera from display , have only one posibilon ,
So, where did the connector that broke connect too? The connector had to plug into a motherboard connector. Once you find where it plugs into you can ohm those points out to see if it is connection too, the USB or the Firewire.
Yes, this could connect up to the firewire if it is compatible. The schematics are showing the USB. The number and color of wire do not match up to USB. However, if it is internal than according to the schematic it connects up to the USB. Perhaps 2 of the wires are for the microphone? When I search for that particular computer it had only one isight web cam that connected to it and that was to the firewire.
