I have a dell monitor that turns the invereor off when an input is attached . The inverter turns back on when the input is removed.
dell e228wfp goes blank
Re: dell e228wfp goes blank
Originally posted by chetreynolds View PostI have a dell monitor that turns the invereor off when an input is attached . The inverter turns back on when the input is removed.
When a signal is applied a different circuit takes over.
Your monitor is a very high resolution monitor, Are you sure your video card can support It?
Have you tried setting your computer to different resolutions, Try starting at a low resolution and work the way up to the highest resolution of your video card.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
can you tell us if those caps are ok?
the reason I ask is, it looks like you have a cap or possibly 2 that are rounded on the top on the psu
hard to tell from the pic
the 2 in question are in pic4 bottom right hand corner cap, and the one above it
they may be your problem
When you put in the input is the power LED green or orange?
Also, it looks like you have some KZG caps in there - these are notorious for failing without any visible signs (meaning they could be bad even though they aren't bloated).
I would remove them then test ESR again on each KZQ cap.
Then again your pictures are blurry maybe I made a mistake about the presence of KZG. But please check! If possible, list the brand and series of the caps in your monitor.
Black caps on video board look 'puffy' - like just beginning to bloat.Mann-Made Global Warming.
- Dr Seuss
Originally posted by shovenose View PostWhen you put in the input is the power LED green or orange?
Those both come in brown too.
I can't read them either though.
- Dr Seuss
