samsung 244t power board
    Ok can anyone identify these capacitors on the 244t power board pslf10141a
    cs852 cm852 cm851 cm861 cm856 cs802 cm810 cs806 cs808 cp811 cm809 cm813
    this is every cap on the power board except the 100uf 450v
    I really need help here matching the values to the locations
    Thanx
    uf TYPE # of Caps
    2200 Radial 1
    1000 Radial 4
    100 Radial 1
    47 Radial 4
    10 Radial 2
    Re: samsung 244t power board
    From pics i took:
    cs852-1000uf 35v, cm852-1000uf 35v, cm851-1000mf 35v, cm861-2200uf 10v
    cs802-100uf 10v cm810-47uf 50v cs806-47uf 63v cs808-47uf 50v cp811-47uf 50v cm809-10uf 50v and cm813-10uf 50v
    anyone agree????? oh boy
      Well no worries--they were correct and the silver 244t is up and working!!!
      Now for the black 244t!!!!
        Hi, what a coincidence. I have the same monitor (silver 244t) and today it wouldn't power up. The little led green light is on but screen is black (no back-light).
        Also, I noticed when pushing the power switch on the front that the green LED light doesn't go off. But of course if I turn the main power switch off (the one located next to the power plug) then the green light on the front goes off.
        May I ask if your monitor exhibited the same issues and would you say from what I've described my power board is in need of repair?
          Chances are, it is a similar fault...looks like you are going to have to open,and some photos, using 'managed items',are always helpful..please do not post photos in line.
            I'm having exactly the same issue on a silver 244T..have a look at my thread and see if my other symptoms match yours
            https://www.badcaps.net/forum/showth...d=1#post200136
            @CJ ...is there a reason why I cant see your pics?
              One monitor had the green light but never lit up at all and the other 244t had a pic but was making a buzzing short like noise which affected the picture. It flickered huge.
              Both had bulging caps on the power board but the monitor that flickered had a bad lead going to the 450v main caoacitor which broke off as i removed it.
              I replaced All the caps and problem solved. The values i posted are correct and the item # from digikey are:
              2200uf 10v p5522-nd
              100uf 25v p5544-nd
              47uf 63v 565-1350-nd
              1000uf 50v (didnt have 35v) p5575-nd
              47uf 50v p10321-nd
              10uf 50v p5567-nd
              100uf 450v 565-1481-nd
              100uf 10v p5517-nd
              digi-key digikey.com $10.75 give or take
                Yep, it sounds like I need new caps. I have yet to open the case but it sounds like you and Tuk have the same issues as I do.
                I'd like to know if its easy to remove the power board and should it be removed when replacing the caps? I ask because I'd like to take just the board over a friends house to have him replace the caps rather that taking the whole monitor over there.
                Also, in the first post of this thread it states there are "1000 Radial 4" yet in the following post it only shows the location of three 1000uf caps. So do I only need three or is there actually four and you just happened to omit where the fourth one goes?
                Thanks for all the help and for posting the part numbers.
                  you have to remove the board to get access to the underside( where the solder is )
                    There is a total of 13 caps which includes the 100 450v. I only listed the part #'s not how many.
                    4 - 1000uf with 3 @ 35v(i had to order 50v) and 1 @ 25v
                    p5544-nd is the 1000uf 25v
                    p5575-nd is the 50v
                    go to dig-key and search the part# to see if the values are correct
                    And yes i still have all the old caps.
