I got a pair of Acer 1913w's that seem to have gone south. (I got them that way)
Cracked them open and replaced the caps on the inverter board. Was rather surprised to see through-hole caps being used on a surface-mount board, but I digress. (Must buy alcohol to clean flux.)
But apparently that wasn't enough to get them working. I'll turn them on, they'll try to fire up the backlight a couple times, and go black. The backlight seems to stay on for a fraction of a second when it tries to fire up. Then the LED turns red.
I selectively checked all the bulbs and they appear to be firing up okay, so I know they're not dead (but still maybe dying). They don't stay on for very long if I run them all at the same time, but I noticed they run for a couple more seconds if I unplug one of them (doesn't matter which one).
Unfortunately, they both died in the same fashion, so I can't mix and match parts to get one working, and I'd hopefully like to get both going.
But another thing I noticed was that the light on the power brick dims when I try to turn on the monitor... but that could also be a symptom of the inverter/backlight wanting too much power. Sad thing is, the power brick is sealed, and I can't get it open. I can probably buy new ones though. The bricks do seem to output 19v, but I don't have a load I can connect it to to test it for current.
These things aren't like my Dells, you change a few caps on those and you got a new monitor... These things seem like a chore.
Anywho, the service manual is garbage as usual, so I'm not sure which is at fault... so... bad PSU, bad inverter, or bad CCFL's?
