Ok, guys & gals, whichever the case may be?....Newbe here.
I aquired this Sceptre X9G Naga V 19". When I first plugged it up for power, there was No power light. but after I left it plugged in for a minute, the power light gradually lit up real dim? I plugged the vga in to a running computer & nothing showed on the screen (I assumed this would happen) since the power light was so dim, (I had to hold my hand around it to be able to see it.)
Ok, so I ordered the caps kit Even though none of the caps looked bad, I replaced all 10 caps & double checked my joints & crossed my fingers as I plugged it in,.... Same thing, No power light?! However, now, after I leave it plugged in for 5-6 minutes, the power light gets brighter & brighter? (never did that before) So now I hit the power button to turn it off, the light goes out,... I hit the power again & it comes on bright green for a split second then goes to yellow. I then tried plugging the vga cable in & nothing happens, no change in light color, no image, no image with the flashlight test.....I'm at a Loss as what to do next, short off trashing it?... Any Ideas or thoughts will be greatly appreciated. Thanks.
