Hello all,
I have browsed your forums and seen many posts regarding the "2 seconds to black issue". Mine is quite similar in most aspects and I have a semblance of my "next step". Just wanted to verify with a knowledgeable community before proceeding.
First off, I am not an electrician. I am a satellite technician so I have some limited knowledge of components and circuitry but i deal way more in frequency theory than component level issues. That said I can "fake it till I make it" and get this fixed, I just know it.
My issue is with a Emachines LCD LE1938 monitor. I took it apart to place it in a suitcase for a small project of mine. It worked fine before I moved it, that is key; it is entirely due to my error that it broke.
So I power it on with a input signal from my PS3 using an hdmi to dvi connector. I get what appears to be full power on my 4 back lights (no noticeable dimness) and I see the "eMachines logo" for about a second, after which the screen goes black. A second or so later the screen comes back on and shows the PS3 Home screen for about 2 seconds. At this point the monitor actually shuts down and the amber standby light comes on the power switch. I have tried shining the flashlight into the screen to see if an image is still present and there isn't one.
Steps I have take so far:
I have replaced 4 capacitors on the board.
470 microfarad/35V
220 microfarad/35V
1000 microfarad/35V
1000 microfarad/50v
The last one was originally a 680 Microfarad/35V but I couldn't find a replacement locally and tried this.
The four replaced caps weren't noticeably bad, however if you closed your eye and jumped on one foot they did seem to possibly have a very very very slight curvature to their tops, nothing like some bad caps i have seen.
Next step:
I have ordered proper rated capacitors for the entire board. I plan on replacing them all in a few days. However, I am not convinced this will fix the problem. Just losing hope that it is something simple I guess
My other thought is that I have a bad CCFL tube. I was reading some other threads saying that a bad tube "could" cause the protection circuit to engage. Like I said earlier I notice no difference in brightness and did not see color distortion, such as red hue, like others mentioned as signs of a bad or aging CCFL but my monitor isn't staying powered with back lights off like others so I am thinking it is a protection circuit engaging.
Does anyone have any other ideas or opinions on this. BTW I know I shouldn't have changed the farad rating with a higher one, but I was antsy to see if it worked, it will all be replaced with proper rated caps in a few days.
PS When I get back from work I will see about compressing the photos I took and adding them to the post. Problem being they are 6MB a piece, so can't attach them at the moment.
470 microfarad/35V
220 microfarad/35V
1000 microfarad/35V
1000 microfarad/50v
Next step:
