This is for information; I realize this has been mentioned before but I thought it might be worth while bringing it up again.
I have a Dell 1707FPc monitor that gave no indication of life {no power led no back lamp or image even when looking with a flash light] opening the monitor up I quickly was able to determine that I had 5v and
13v showing up at the video board. Voltages also looked at the voltage regulators.
The next thing I decided to check were voltages at the ribbon cable going to the front control buttons. When I did this I accidently raked my testing probe across the ribbon cable and all of a sudden the monitor came to life. There is an obvious problem with the pled button you cannot feel the clicking of the button when it is pushed, but by tricking the video board to thinking it was pushed [by causing a voltage change] The monitor will work and continue to work even after unplugging the power cord and reconnecting the power cord. It continues to work even with the button ribbon cable disconnected.
I HAVE A FEALING I MAY HAVE BEEN EXTREAMLY LUCKY NOT TO HAVE DAMMAGED SOMETHING BY RAKING MY PROBE DOWN THE RIBBON CABLE.
Just recently, A very senior member responded to a thread about powering on a monitor without a front control buttons. It was suggested to.
“Use a 1KΩ resistor from ground (black wire) to each of the colored wires and see if you can trigger it. If that doesn't work, try a 470Ω. Keep dividing the value by 2 until you find a value that works. Using the resistor method prevents you from dead-shorting a power supply lead, as one of those wires feeds the power-on LED.”
Thank you.
Also from my reading in this forum it has been stated that just because the power LED does not work that does not mean that the monitor will not work, You may initially have to do something to power it on[by using the resistor, To change the state of the voltage of the PLED].
So at this time the only way for me to completely power the monitor off is to unplug power from the wall outlet, but the monitor will power back on to its last state without doing anything but plugging the power cord back it. For my personal use I don't care about having a non working power button.
Thank you every body for all the good information given in this forum.
Every monitor I work on I learn or get to practice something new.
Al.
Thank you.
Al.
