I see a 5 pack for $15 out of Hong Kong. $3 seems fair when new from Arrow were almost $1 in small quantities. I looked through my collection of laptop boards and found several of the above MOSFETS including a few SI4392.
The SI4392 on ebay have a different number set on the top than the ones installed on my motherboard. Honestly I don't know the difference, otherwise I'd make a decision about that now.
The 8170's are $15 for two, so I can grab those I guess. I'm trying to get this out of the way quick-like, so was avoiding Hong Kong. I've had this thing laying around too long.
i have this same board and replaced both mofets and is kicking the power supply off on overlode i can plug a fan in to supply and it works so i know its good and i can pull 4 legs off 1 side of the mofet (dont mater witch one or side) and it wont set off power supply so im thinking im not far dose any one have any idia were i can go from here
So, this seems to be a common issue with this model laptop.
I too have the power supply in protect mode when plugging it in issue.
On mine though, nothing is clearly burned.
Both of the mosfets on mine are TPC8107s that are on the underside of the board by the power jack.
One is just 'upside down' from the other.
I'm sure you can see in the OPs pics.
Wondering if replacing both of the TPC8107s there would fix the problem, or if I'd also need to find the Si4392 and replace it.
I know it's an old thread, but if people having this issue see this and we figure it out, it would seem to help many folks.
I ordered a 5 pack of the TPC8107s I replaced all 3 of them on the board. It still goes into protect mode. I've visually inspected the whole board and I see nothing burned or cracked. The video card on this unit did not fail as I put it in another unit and it works fine. Only think I can think of is maybe a BGA failure on the north or southbridge. It doesn't work on a charged battery either. No lights, no nothing. Just protect mode on the PS which works fine on the other unit. Anyone else have any ideas?
