Logitech Z-5500 recap and speaker connection mod.
    Re: Logitech Z-5500 recap and speaker connection mod.
    Hello!
    I just opened up my z5500 console and i was wondering if there are some caps that can be changed for a better sound. I am planing to change the op amps anyway with some LM4562MA. Here are some pictures
    The first one - the opamps 6 of them R45801(I) i cant say the last letter is 1 or i, anyway :http://www.alldatasheet.com/datashee...TI/R4580I.html
    The second one the entire back side pcb where all the key components are (DSP -- CS 494003-CQZ, DAC-- CS 5351 KZZ, CS42526-- i don't know what this is..)
    The third one detail of the DACs.
    You can also see the caps in the console. Does it worth replacing some of them?
    I have more pistures taken if you want some more just say so.
      So the 4700uF, 25V, is that the power supply cap? Should I use the low ESR cap to replace it or should I leave it alone? Also, if it's the power supply cap, does it hurt to use a bigger capacity cap that is higher than 4700uF, 25V? Would replacing this cap matter to the sounds?
      Thanks,
        Would you list the steps to get at the capacitors? I cannot seem to get to the bottom of the circuit board to unsolder the capacitors.
        Thanks.
          you might run into a problem, its called voiding your warranty. Normally, I would not care, hell I would be the first to do so. However, the Z-5500 eventually runs into a problem with the console. Where it the backlight on the lcd eventually dies, and sometimes it locks up when taking a optical input when you first turn it on. Mine does so and i'm not the only one.
            please can someone tell me the values of the resistances r21 and r22 in the mainboard of sub i really apreciate this i can give 10$ if some one send me a clear picture
