Half a year ago, I repaired my S750 woofer.
Half a month ago, I bought a failed S750 woofer to repair for fun (I'm still a newbie). There were some obvious failed parts on the PSU board I checked, and I may fixed them.
The current issue
After fixing, I plugged power line, the green LED on back plate lights up, the red standby LED on control pod also lights up.
Exciting! (Donald Trump's WINNING face emoji)
I continue to press the 'STANDBY/POWER' button on control pod. The 'MASTER' LED lights up!
I plugged audio line to a radio, but no sounds came out.
Hmmm... it reminds me that I didn't heard the click sound of relay when press the 'STANDBY/POWER' button on control pod.
So I measured the voltage of each pin of CN6 connector, I found that the reading value is about half of expected value it should be.
Now I'm lost, what reason it could be?
Extra information I don't know if it can help:
One more thing, how could low voltage makes back LED & control pod LED works?
- D9 - 1N4004 - short circuit, replaced.
- D13 - 1N4148 - short circuit, replaced.
- R9 - 6.8Ω, 1/4W - open circuit, replaced.
- U7 - TOP243Y - it was replaced with a TOP249Y by the previous owner, I don't know if it's okay, but I replaced it with a new TOP243Y. And the solder pads are off except 'C'. And a piece of copper on the other side is missing which makes an open circuit, I fixed this too.
- C59 C60 C69 C70 - 200V/470μF - most of them are bulged, so I replace them with 4 Chemi-con KMM series capacitors (not long-life series, but should be okay).
- C61 - 450V/68μF - no obvious bulge sign, but I replaced it with a Rubycon TXW (long-life series) 450V/82μF capacitor.
- C62 - 25V/47μF - It was replaced with a Rubycon YXA 63V/47μF by the previous owner, since YXA series only have 1000 hours life, so I replaced it with a Rubycon ZLH 63V/47μF capacitor. Also, there's explosion sign under it's legs, a piece of copper missed.
- C63 - 50V/0.1μF - no obvious failed sign, but I replaced it with a Nichicon UMV 50V/0.1μF, it was an extra components from my previous repair.
- C7 - 250V/470pF - looks like it was replaced by previous owner, I leaved this one wihout replacement.
- FUSE - 250V/3.15A - It was replaced with a 250A/10A one by previous owner, I'm afraid it can't protect the boards inside, so I replaced with a standard 250V/3.15A one.
The current issue
- T3 - After took this woofer home, open the back plate, I smell something like humidity, so I leave it opened for several days. But it still smells like that now, especially when put my nose close to Transformer3 - the one related to the standby circuit. Could it be transformer 3's fault?
- U2 - optocoupler - Since there's explosion sign under C62, U2 is closed to C62, could it be affected and failed? By the way, the voltage of Vce(4 pin to 3 pin) is around 5V.
- U3 U4 U5 U6 - The input voltage and output voltage (obviously) of these regulators are low too.
- C64 C65 C73 C78 C74 C66 C75 C68 C76 C77 - I didn't replaced those electrolytic capacitors, could these capacitors caused low voltage?
