Was looking through some schematics and saw a 0Ω resistor. What is the point of having a resistor if it isn't even 1Ω?
What's the point of a 0Ω resistor?
Permanently Retired Systems:
Kooky and Kool Systems
sigpicTags: None
Re: What's the point of a 0Ω resistor?
Can burn out if too much current/voltage is applied Ie S/C further downline so can act as a fuse. Vestel do this all the Tv with their Tv boards use 0ohms as fuses. But they can also act as links etc.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Oh OkDon't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
Originally posted by stj View Postthey are often fitted because you can lift them to isolate parts of a circuit,
or because they need to bridge over some other tracks, and old pick&place machines couldnt auto-insert jumpwires.
but they could insert resistors.
if you crush a 0-ohm resistor you will find that atleast 50% of them are actually a continuous copper wire or even a metal sleeve and not a carbon or metal-oxide device at all.
i just murdered one for you.
pic1 - as it was desoldered.
pic2 removed the paint - looks like a plated metal body.
pic3 - crushed it in a crimp tool - it's solid copper with tin plating!!!
Originally posted by TechGeek View PostWas looking through some schematics and saw a 0Ω resistor. What is the point of having a resistor if it isn't even 1Ω?
But there's also another reason:
They are often used as a jumper nowadays. Like on AMDs Radeon RX480 reference Board, there are a couple of 0 Ohm Resistors used to adjust the distribution of power. Ie if the Power comes from the PCIe slot or the Power cable.
With this knowledge you can also modify some graphics cards to run either totally off the cable or the slot.
HmmmDon't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
