Hi Guys,
I have a nyko databank that allows a 3.5" HDD to be used with a PS4.
The thing has stopped powering up any HDDs (the HDDstill works in a PC)
I have traced the issue to the 12V power supply. when sitting idle the power jumps all over the place as in this video:
https://youtu.be/7jh1wkTOnXQ
You can hear the beep when i switch it on but then the voltage reading goes nuts.
The 5v comes from the console but plugs into the smaller white connector on the power supply (either to switch it on or just allow the 5v to pass through to the larger connector where both 12v and 5v run up to the sata plug)
5v seems fine: https://youtu.be/xQZaVRKtNks
The soldering quality is also not so good with a lot of joints that will at least need a reflow to make me feel happy. It also contains Jwco and Chong Capacitors that I should also replace if I want this thing to live a long time.
Everything else looks ok, i'm not sure where to start on this one.
