About 4 months ago my monitor starting making a high pitch noise when turning on and off. At first it was no big deal, but soon the monitor would turn on to a white screen and require turning the monitor on and off multiple times in order for the picture to finally show up.
I checked around and it seems like some others have had similar problems and it was caused by the capacitors being blown. I just opened up the monitor (pain in the ass) and it looks like the tops of the two larger black capacitors have started to push out and have a little bit of brown on top. They still don't look anywhere near as bad as others I've seen in other peoples pictures... so I was wondering if they look like the cause of the problem. I wiped a little of the brown off the top of them, but you can kind of tell how they are different than the others.
It looks like only the two large black capacitors need to be replaced because all the green tops are still flat. Does anything else besides the two black caps look strange and where should I get the replacements?
