I had one of these that had a shutting down issue, turns out the motherbord PCI-E main was overloading causing shutdowns. I took it back, got the new one and after some time, the two video cards would burn the atx pins over time, causing corrosion and eventually the same problem (corrosion causes vdrop and increase pull)
I replaced the connectors with clean ones, but I think I soldered the wrong wires. As they are three of the same color, but two of a different thickness. When I put it back in, turned it on, it fried the video card, which of course is on the PCI-e wires I soldered. I looked on google images and it didn't help. Does anyone have a TX850W. I has to be that model. the 950 and 750 are wired differently at the atx connector
and yes, on this PSU, two wires go to a single connector, but I think I made a mistake of which ones
