SCSI drives
    Re: SCSI drives
    Well I rummaged through the stuff I got with the server drives and I have an Adaptec SCSI PCI card 19160/29160 N. but I am still none the wiser what I need in cables
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
      Re: SCSI drives
      First post another pic of the drive so we can see the connector end. Then tell us how many drives you have or will be using.
        Re: SCSI drives
        As far as I can tell it only has this wide connector
          Re: SCSI drives
          Ah ok, designed to be put in a caddy and slid into a server then.
          Not sure if you can get cables for those...
            Re: SCSI drives
            Cable needed is here:
            http://cgi.ebay.com/68PIN-Ultra-320-...item2c5b436bc8
            Adapter needed is here:
            http://cgi.ebay.com/New-SCA-80-68-PI...item4aa2f50ba6
            You need one adapter for each drive for these 80-pin SCA drives
              Re: SCSI drives
              Those are 80 pin. You will either need a backplain or 80-68 pin adapters and a 68 pin cable with with 1 connector for the card and 1 per drive plus a terminator on the end. The adapters arnt expensive the cables can be if you buy from the wrong place. Backplain would be a good route if you have a case that will let you mount it in and you can find one at a good price.
                Re: SCSI drives
                or a cage (not just a blackpLANE)
                http://cgi.ebay.com/5-drive-Hot-Swap...item255cec6f35
                I actually have two of these
                  Re: SCSI drives
                  Get a external box like an HP disk system, it will be cheaper.
