This tv was thought to be hit by lightning or a power surge. When plugged in, it shows nothing, no yellow or white logo. I was hoping it was a blown fuze, so I checked it for continuity and it looks ok. I then turned the board over and at the upper left hand corner of the board, put the blk lead on the ground terminal and the red lead on the N terminal, and it shows 124V. I moved the red lead to the L terminal and it shows nothing. I then moved the red lead up to the left side to the fuse, and again, nothing. There is a solder joint "between" the two prongs of the plug, (between N & L) but I don't know what it is for. Shouldn't I have the same voltage (124V) at the left side of the fuse and if so, what do you think is the problem? Keep think I'm checking something the wrong way!
Thanks for any suggestions!
