I'm having a problem with this power supply (LC8650). It appears to be working fine but the fan is not turning which makes the power supply overheat in about 5-10 minutes, depending on load. I suspected that the fan was broken so I tried two other fans but none of them worked. They just twitch a bit and immediately stop.
Voltage on the fan connector is 12.15V (measured at fan connector pins while the fan wasn't connected).
Any ideas what's going on?
Cheers
Cheers
