MSI MD-7226 K9N Diamond
    A few weeks ago, I discovered that my gaming rig would no longer power up and immediately jumped to the conclusion that I had another cheap power supply failure (when will I ever learn?). After installing a fresh PS, I was dismayed to find that the PC still would not boot. I tore down the computer and immediately noticed that several caps near the PCI-e slots were bulged and leaking. I'd heard a few rumbles here and there about bad capacitors and a Google search led me here.
    After wading through these forums, I determined that I had indeed been beset by the well-known Chemicon KZG problem. Fortunately, it seems that MSI only used these problem caps in one critical area: the PCI-Express slots. All of the caps around the CPU are Sanyo and Panasonic. There are a few other KZG's in other areas on the board but not in any likely high-current areas, I hope. I just ordered enough new capacitors to replace the ones near the slots and with any luck, I'll have my gaming rig back up and running even though I haven't done any PC gaming for almost a year.
    With what I've learned here, I know I'll be checking other boards and power supplies for bad caps at the first sign of trouble and do a pre-emptive recap on any that look questionable.
    Re: MSI MD-7226 K9N Diamond
    if you have a pci video card, try to put that in there and see if it will boot up
    I hope the KGZ's didn't burn your video card out. if you have another rig try to put it in there to verify it works
      Unfortunately, the motherboard won't even power up for more than about 0.5 seconds. I suspect that the bad caps are keeping one or more voltages from coming up to spec within the allotted time (500ms, iirc) and causing an immediate shutdown.
      I figure a $20 gamble on a $180 motherboard is worth a shot. If it fails,I'll just take the plunge and upgrade to a new AM3+ board and CPU.
        What brand of power supply are you using?
          Also try it with the ATX12V CPU connecotr un-plugged. That may just tell us what part of the board is at fault. If it powers on with the 12V connector out, the one of your VRM MOSFETs is probably shorted.
