My next project involves an older 19" Monitor that I think was originally sold by Compusa, called Norwood Micro model M19BBK. I believe it was also sold under the name Star Logic.
There is no power when pressing the button. No leds, nothing, completely dead. The ac adapter was swapped - no help.
I checked a few things I could. All caps are flat and not leaking, so I guess that means they may be good or bad. The fuse (F2) is good and there is 12.33Volts at the fuse. The Diode at F1 (I thought fuses were normally labeled F_ ) meters out on the DMM diode setting and there is voltage, 12.33V on one side and 0 on the other using the board screw hole as ground for the probe. The regulator at U4 has no voltage - so power isn't getting that far. The component at U11 (which is right next to F2 by the power jack) (some sort of regulator?) measures 2.25V, 0, 12.33V (using board screw hole as ground). Theres another component at Q5 that has no voltage on any pin. BTW: I checked all voltages with the inverter board and LCD screen disconnected.
It looks like the power to this board stops early in the circuit. I'm still very much a beginner at this, but hopefully someone can give me some tips on what to check.
Pics are attached - let me know if you need any more info or pics.
Thank you!!
Thank you!!
