Dell 1800 fp screen blown power board
    the wire diagram for a dell 1800 fp if your power supply is blown
    Intel Pentium Dual Core E2200 2.2 GHz
    Asus 775 P5KPL-CM
    Asus EN9400GT Silent
    4gb ram
    Cat 32 inch monitor
    2x 500gb maxtor ide and western digital sata
    Fixed projects:
    dell 1800 fp 18,1 inch screen
    cicero lcd 17 inch screen
    hd44780 2x20(from isdn phone) lcd screen on parralel port displaying pc stats
    Re: Dell 1800 fp screen blown power board
    there is only one wire cabel that is like this so its easy to fix it no need to worry about the power for the backlight its on the smaller board that gets power from the molex if your done making the connector keep in mind not to exceed 1 mtr of cabel becouse if you will it will not give you any screen @ all
    Asus 775 P5KPL-CM
    4gb ram
    Cat 32 inch monitor
    Fixed projects:
      That is because the device to be powered doesn't have sufficient capacitors, due to cable length and resistance (thin wires are like that) is enough to drop voltage and increased ripple.
      Careful with the color and labeled wires, this one you show is poorly drawn. Be accurate. There are many who take this at face value and their monitor blows up.
      Cheers, Wizard
        Careful with the color and mislabeled wires, this one you show is poorly drawn. Be accurate, put info on which is which for each wires. There are many who take this at face value and their monitor blows up.
        Also, there is no such as -5v and +5v WITHOUT ground. We always draw ground if the pins measures fraction of ohm to the chassis ground.
        Just a note: very rarely a unit might have isolated supply island that is seperated from main ground, especially in units that have audio. I see this occassionally in TVs and some good audio combined with other systems in one. That will have extra text to the voltages like this for example: It is easily seen when you study one of those power supply that measured with no connection between audio supply and the other supplies especially ground paths. And good designer always put for every wire of power gets at least one ground wire to prevent ground loops through other chassis if number of ground wires is insufficient. Generic units are notorious for skimping on this.
        12V
        12V
        5V
        ground
        ground
        ground
        audio_ground
        audio_ground
        audio_+24V
        audio_-24V <---sometimes have dual supply with this -V supply when a ampifier uses pull-push design (better than most single supply audio amp.)
        Cheers, Wizard
          well poorly drawn you can clearly see that wire 1(blue) and 2 are connected together 3 and 4, 5 and 6, 7 and 8 and the negative 5 is ground thats on the pc power suply and the negative 12 is ground also
          Asus 775 P5KPL-CM
          4gb ram
          Cat 32 inch monitor
          Fixed projects:
            the color of the wires is as they are one blue and the others are all grey, and the molex are the standard colors dont wanna be rude but even my boss who has no knowledge of electronic understands what i have drawn.
            Asus 775 P5KPL-CM
            4gb ram
            Cat 32 inch monitor
            Fixed projects:
              You would be surprised the kind of people that lurks around here.
              • ASUS ROG Maximus IX Code
              • Intel Core i5-7600K 3.8GHz
              • Windows 10 Pro x64
              • GeForce GT1050
