Hello all,
I have a Samsung LE40A656A1FXXU which has a problem displaying a picture. From cold the screen appears to be split into three sections. The leftmost third has some sort of refreshing problem and while watching everything is smeary and blurry as the picture being updated. The middle third of the screen is dark although you can still see the picture and the rightmost third appears as normal.
Taping around the edge of the screen does not have any effect. On several occasions after being on for 30 – 40 minutes the picture has returned to normal. Taping around the edge of the screen and on the circuit boards does not bring back the fault once it seems to clear. Only when the set has cooled down and is switched back on does it return to the faulty display.
Having replaced the TCON board I can rule that out as faulty but I have just noticed that bringing up the screen menu when the middle of the screen is dark has no effect on the menu colours which are as they should.
Would I be correct in thinking I have a video fault on the main AV board?
Any advice gratefully accepted.
CN801 readings with the set on.
P1 3.6v P2 1.95v
P3 5.01v P4 0.0v
P5 0.0v P6 0.0v
P7 12.7v P8 12.72v
P9 0.0v P10 0.0v
P11 0.0v P12 0.0V
P13 4.96v P14 4.96v
P15 4.96v P16 4.96v
P17 0.0v P18 0.0v
P19 12.75v P20 0.0v
P21 12.75v P22 12.75v
P23 0.0v P24 0.0v
CN803 readings with the set on.
P1 4.82V
P2 0.0v
P3 3.22V
P4 4.82V
P1 3.6v P2 1.95v
P3 5.01v P4 0.0v
P5 0.0v P6 0.0v
P7 12.7v P8 12.72v
P9 0.0v P10 0.0v
P11 0.0v P12 0.0V
P13 4.96v P14 4.96v
P15 4.96v P16 4.96v
P17 0.0v P18 0.0v
P19 12.75v P20 0.0v
P23 0.0v P24 0.0v
P1 4.82V
P2 0.0v
P3 3.22V
P4 4.82V
