Capxon KF replacement
    I'm currently searching to replace capacitor to do my first recap for replacing 2 Capxon KF in a power supply for a LCD display (viewsonic vp930b)
    I have search on Newark for similar specs.
    Now I have found 2 possibilities with higher Ripple and lower impedance.
    The two options I have found have the same specs and are available so I want to know if I should just chose randomly or if I have forgot to check something.... I don't really know the brand for capacitor so maybe one have a better reputation...
    Spec:
    In all case:
    -1000uF
    -16 v
    -105 C
    -Ripple at 105 C - 100 khz
    -Impedance at 20 C 100 khz
    -Size: 10*20
    Original capacitor:
    -Capxon KF
    -Ripple: 1350 mA
    -Impedance: 0,065 ohm
    option 1:
    -RubyCon ZL
    -Ripple: 1820 mA
    -Impedance: 0,023 ohm
    option 2:
    -Chemi-Con KZE
    -Ripple: 1820 mA
    Thanks,
    Neurotox
    Re: Capxon KF replacement
    I'd take the rubycon
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      iirc kze likes to go bad in high heat... rubycon please!
      sigpic
      (Insert witty quote here)
        zl for the win.
          That would be KZG/KZJ series, not KZE.
          United Chemicon KZE and Rubycon ZL are equivalent. The Rubycons may be more expensive, but they are Rubycons after all... High quality stuff .
            Correct...
            Nothing wrong with KZE and they are equivalent to ZL.
            ZL are -supposedly- higher quality. No actual proof of that. Just opinion.
            If I had to order either way I'd get ZL.
            The black ZL look so much better than ugly green or brown KZE.
            But, if I have some KZE handy I wouldn't order ZL instead.
            Mann-Made Global Warming.
            - Dr Seuss
              Agreed. There is nothing wrong with KZE and I have used them in repairs before, but rubycon are a better regarded brand
