Re: Samsung PN60E550D1F no audio no image only red LED
Your VE is also low, you said in first post 10V, should be around 110V. Also you VSC scan is too low as already suggested. You may have bad ysustain and x main also. Remove your xmain and check Y sustain VSC again. When you unplug the board give it few minutes to discharge before reconnecting so you don't short the board.
when i remove the xmain to check vsc voltage do i reconnect logic board to the ysus board or leave disconnected?
Ok so I rested xmain as suggested
I disconnected the xmain cable going to the ysus
Logic board disconnected from the ysus and xmain
VE 10.92v no green led blinking
Logic board connected to xmain
VE 16.42v with green led blinking
Logic board connected to the xmain and ysus
VE 10.90v green led blinking
Logic board disconnected from the xmain
Logic board connected to the ysus
VE 10.90v no blinking green led
So I tested the vsc on the ysus
With the xmain cable disconnected from ysus and logic board connected to ysus the vsc tested -0.028v and dropped to -0.0000
With the xmain cable disconnected from ysus and logic board disconnected from the ysus the vsc tested -50.6v
I dont understand how that is if there is no cables connected to the ysus????
That brings us back to the older recommendation of replacing y-sustain board. If you cant find cheap Y-systain send it for repair or try to purchase repair kit.
Vscan is generated off the ysus. If you remove the flat cable connecting the ysus to the logic board you will have improper vscan readings. I also think your ysus is faulty.
Check for faulty shorted mosfets on the ysus. Also open fuses and open resistors.
With an ohmmeter put the black leg on to the center pin of each MOSFET. the red probe and check end pins of any of those and of any are shorted then that's your problem to start with
Usually not. But it is possible in some rare instances if the buffer board fails for the Y-sustain to be damaged too. And the buffer can fail quite often with damaged panels.
You should have ordered also the y-sustain repair kit from shop jimmy, it comes with all parts that are usually shorted and with each part location. Anyway I would recommend not to install new x-main board when installing ebay y-sustain. Install new y-sustain board with x-main unplugged and measure your VCS first. if your VSC voltage is correct then install new x-main. Your old x-main may be OK since VE is created by y-sustain. Let us know how it turns out.
