Hello again everyone. I was watching TV the other night and it was working fine. This morning when I turned it on, it won't power up. The standby light is ON and when I press power, the standby light flicks off, then on again (and remains on) but nothing happens. There is no picture or sound nor does the TV come on.
I have pulled the power board and I'm not getting ANY voltages except my 5V standby power off the "SB" pin that goes to the main board.
I downloaded the service manual but there is a major problem. All the troubleshooting and diagrams have DIFFERENT numbers and names than what's on my board. My power board is a BN44-00214A. I've pulled EVERY capacitor including the big one out of the board and bench tested it. They all check OK. The Blue capacitor on the board is also ok.
Are voltage loss % around 2-3% mean the capacitor is bad?
Here are some readings:
CM861 - 3677UF 1.8% Voltage Loss
CM868 - 697UF 1.3%
CM858 - 678UF 2.5%
CM856 - 470UF 3.6%
CM582 - 682UF 2.0%
CM851 - 695UF 1.3%
CB852 - 2076UF 1.5%
CM808 - 17.7nf 17ΩESR
I checked the solder joint on the (transistor/bridge??) QB802 and it looks fair. I manged to scorch the board near there too. I pulled it and cleaned it and added my own solder. I haven't tested it yet except out of circuit and with my MM. With Red prong on left lead and Black prong on right lead (nothing in middle) in diode mode I get .62. I don't get readings any other way or combination.
I'm getting NO DC voltages anywhere else on the connector pins that go to any other part of the TV. I'm not getting 24V or my 12v or my 5.3v etc.
How do I test that QB802 and what else do I need to check. I DID scrape all the glue off all major components. I also checked the big cap but forgot to write the values down, but they were within the 10% limit.
I referenced the service manual and see the flow chart on page 4-2 says step 2 to check 5V at D1001. I don't have a D1001 on my board.
I attached a clear well lit picture.
Has anyone had similar problems with this unit and manual? I searched the forum and saw the same model TV having problems, but my problem is different.
CM868 - 697UF 1.3%
CM858 - 678UF 2.5%
CM856 - 470UF 3.6%
CM582 - 682UF 2.0%
CM851 - 695UF 1.3%
CB852 - 2076UF 1.5%
