I recently got a Samsung LN32C530 from a friend because it did not turn on. When it is plugged in the standby light turns on, but when you hit the power button it just blinks 4 or 5 times and then turns off. The person who had it before me thought it was the capacitors so they replaced those and I thought it was the main board, but after replacing that the tv will still not turn on. I have attached pictures and would appreciate any help given.
Samsung LN32C530 will not turn on. Standby light just blinks
Re: Samsung LN32C530 will not turn on. Standby light just blinks
The capacitors that were used as replacements appear to be general purpose, and are completely insufficient for the application they are used in.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by mmclende View PostOk, what type of capacitors do I need?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostPanasonic FC, FM and FR are commonly suggested around here and can be acquired from Digi-Key for about $10 total. The question is - did the person replace all caps correctly, so are the specifications (uF and voltage) correct? You cannot be certain...
Originally posted by mmclende View PostNo I can't say. I found the schematic for the board so I'll verify that the capacitors match that. Are those capacitors something that I can go to Radio Shack or somewhere to get or would I have to get them online?Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
Looks like Digikey has a better supply of FM's. Get the uf and voltage along with sizes and you want radial type caps. Try this URL:
http://www.digikey.com/product-searc...c%20Fm&stock=1
You should be able to get what you need. Get shipping by First Class Mail it will get there in 2-3 daysHave you ever stopped to think and then forget to start thinking again?
Originally posted by killian6pk View PostLooks like Digikey has a better supply of FM's. Get the uf and voltage along with sizes and you want radial type caps. Try this URL:
What happen if you disconnect the cables to the Inverter board? By the way, does it make that Samsung start up tone?Last edited by budm; 08-21-2012, 09:55 PM.Never stop learning
Originally posted by budm View PostWhat happen if you disconnect the cables to the Inverter board? By the way, does it make that Samsung start up tone?
That usually indicates a problem with the main board but pictures are really not good enough for troubleshooting j- they should be a s clear as these
Examples of what is needed
https://www.badcaps.net/forum/attach...1&d=1290283049
https://www.badcaps.net/forum/attach...7&d=1280167246Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostThat usually indicates a problem with the main board but pictures are really not good enough for troubleshooting j- they should be a s clear as these
Are these pictures clear enough? I believe it is a problem with the Main Board also, but I can't narrow down the issue. I have already bought a new main board, but it is possible the new one has the same issue.
Check all regulators... https://www.badcaps.net/forum/showthread.php?t=22232Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostCheck all regulators... https://www.badcaps.net/forum/showthread.php?t=22232
1117z right
pin 1 - 0
pin 2 - 1.26
pin 3 - 3.39
1117z left
pin 1 - 0.64
pin 2 - 1.9
pin 3 - 3.3
7805
pin 1 - 12.3
pin 2 - 0.01
pin 3 - 5.07
950T45
pin 1 - 3.4
pin 2 - 0.01
pin 3 - 2.5
Originally posted by mmclende View PostI checked the regulators and they all seem to be working fine. These are the results I got.
1117z right
pin 1 - 0
pin 2 - 1.26
pin 3 - 3.39
1117z left
pin 1 - 0.64
pin 2 - 1.9
pin 3 - 3.3
7805
pin 1 - 12.3
pin 2 - 0.01
pin 3 - 5.07
950T45
pin 1 - 3.4
pin 2 - 0.01
pin 3 - 2.5
Any advice would be much appreciated.
I know there is a firmware update, but i can't apply it because i can't turn the TV on. I'm also not convinced it would do anything.
I have researched this issue on the model extensively. The problem is almost always the Main PCB. So much so it is very difficult to find any supplier that has a new, refurbished, or even a used one.
Does anyone know of a shop that you can send these to for repair?
