I have Intel D845GRG motherboard with intel celeron 1.8 Ghz processor.
The board is not turning on except stand by light and green power light on casing.
I have also tried change the PSU but nothing worked.
Only way to run it is to short green and black wires on main power connecter on board. I have not got any problem in this way of running it and found no over heating every thing runs properly and cpu tempreture goes to 58 degree celcius.
The "stand by" light is on, and voltages are under 3% limit.
I have also tried to start it by removing all wire from front panel connector and then shorting the power on leds of front panel connector, but nothing happened.
12v and main power connectors are connected rightly.
Also I have two slightly swollen capacitors along side processor socket 6.3v 3300uF.
Also the one of set of green wires at back of board have very small screw driver scratch.
