Samsung 2493 HM issue
    Re: Samsung 2493 HM issue
    OK, I did some measurements as per
    https://www.badcaps.net/forum/showthread.php?t=15796
    Post number 9 by Plainbill and I have a different results:
    With monitor turned On
    Between pin 3 and 1: 0.02v
    Between pin 3 and 2: 16.4v
    Between pin 3 and 4: 1.08v
    Between pin 3 and 5: 378V
    With monitor turned Off
    Between pin 3 and 1: 0v
    Between pin 3 and 2: 14.88v
    Between pin 3 and 4: 0.67v
    Between pin 3 and 5: 160V
    Any idea on what it means ??
      Pin 1 is OCP (Over Current Protect). The change in voltage indicates the standby power supply is putting out more current.
      Pin 2 is Vcc.
      Pin 4 is the feedback (Indicates if the power supply output voltage is too low or too high).
      Pin 5 is the startup voltage. The change in voltage indicates the PFC front end is working.
      All of these readings indicate the standby SMPS, and the standby processor are working properly, and the signal to turn on the main power supply is being received by the power supply. Now it's time to troubleshoot the main supply.
      PlainBill
        Thank you all for your help ..... do you have any idea on how to do that ?? I'm really new at this !!
          I will need a picture of the bottom side of the power supply. the picture of the top is excellent, something equivalent of the bottom would be helpful.
          Also, ICM801? (the 16 pin IC) is the SMPS controller for the main supply. Pin 1 is in the upper left corner, and pins are numbered counterclockwise. Pin 4 is Gnd, I am interested in the voltages on pins 5, 9, and 15.
          PlainBill
            Here are some more pictures !!
            I wil do the voltage measurements in a few minutes !
            Just in case you're wondering the 16 pins IC (ICM801) has a number on it :
            MC33067p
            CPDT0744G
              Ok, here are the measurements on ICM801:
              Monitor switched On
              Between pin 4 and 5: 5.08v
              Between pin 4 and 9: 14.60v
              Between pin 4 and 15: 15.03v
              Monitor switched Off
              Between pin 4 and 5: 0.01v
              Between pin 4 and 9: 0.01v
              Between pin 4 and 15: 0.01v
                Monitor switched On
                Great picture quality, but has been a failure to communicate. I need a picture that covers the entire bottom of the power supply, just like picture 100_4219 covers the top.
                The voltages into ICM801 indicate it should be operating. The voltages you measured are on the input side of the IC, before I have you make measurements of the output side, I want to make sure there are no voltages likely to damage your DMM.
                PlainBill
                  Oops, sorry about that !
                  This one should be better
                    Yes, much better. And I've verified that the output of the chip is driving a transformer at low voltage. For the following measurement, use pin 13 as the ground point. If you would, measure the voltage on pins 12 and 14. Do this with both monitor off and monitor on, and try it with the meter on the DC Volts range, then try it with the meter on the AC Volts range.
                    PlainBill
                      Thank you again PlainBill !
                      Here is what I have:
                      Monitor ON
                      Between pin 13 and 12: 14v DC / 14v AC
                      Between pin 13 and 14: 0.3v DC / 0.3v AC
                      Monitor Off
                      Between pin 13 and 12: 0v DC / 0v AC
                      Between pin 13 and 14: 0v DC / 0v AC
                        Monitor ON
                        Monitor Off
                        Those readings indicate the SMPS controller is turning on, but I don't have any idea if the outputs are active or not.
                        OK, one more thing to try. Insert a .01uF capacitor (Radio Shack Catalog #: 272-131 or similar) between the meter probe and the test points. This will remove the DC component, so simply perform the tests again with the meter on the AC range.
                        I suspect the SMPS controller isn't producing a drive signal, but it's hard to be sire without an oscilloscope. (What we really need is a $20 200 Mhz analog scope).
                        PlainBill
                          Ok, then I will buy one 0.01uF capacitor tomorrow if possible and retry it again !
                          How much do you think a ICM801 SMPS controller cost ? Is it cheaper than an analog scope ?
                            Sorry, my sarcasm (directed at the Fates) doesn't come across properly. Someone in Malaysia is selling them on eBay for $8 + $6 shipping. We aren't quite at that point yet.
                            A decent analog oscilloscope will run over $100. There are cheap digital scopes that connect to a computer using a USB port, but those present problems. In simple terms, you can't trust their results on a complex waveform. Also, neither can be used to troubleshoot power supplies until you get an isolation transformer.
                            PlainBill
                              Thanks for your quick reply ! I'll start by buying the capacitor then
                                Hello, I'm back !
                                I didn't find the exact same capacitor but I took a 0.01uF 630V.
                                Here are the results in AC mode:
                                Monitor ON
                                Between pin 13 and 12: 0v AC
                                Between pin 13 and 14: 0v AC
                                Monitor Off
                                In the beginning, my fingers were in contact with the 2 "branches" of the capacitor and I was reading 25.5v between pin 13 and 12 and 0.7v between pins 13 and 14 with the monitor On and 0v with the monitor Off.
                                I guess the current was going through my body right ?
                                  Hello, I'm back !
                                  Monitor ON
                                  Monitor Off
                                  Something like that.
                                  Whoops!!! I almost made a huge mistake. Or maybe not.
                                  The data sheet shows pins 12 and 14 connected directly to the driver transformer. For several reasons that is a bad idea, and it would not be possible to have 0 volts and 14 volts at the same time on the two outputs.
                                  This power supply uses a resistor and a capacitor in the drive lines. Also, there may be a problem trying to measure the drive voltage. The typical SMPS runs at 40 - 70 Khz. This is designed to run at 1 Mhz!!! Still, I'm not comfortable with the output voltages you measured earlier. They should have been at some intermediate voltage in my opinion.
                                  First, with the power LED on, measure and report the voltage on every pin of the MC33067P. Use pin 4 as the ground point. I'll examine the data sheet and make sure all of them are reasonable.
                                  Also, I've marked up one of the pictures.
                                  I've circled two components in yellow. These are the resistor and capacitor I mentioned earlier. Measure the resistor, and verify it matches the number on it. Examine the cap carefully for any signs of damage.
                                  I've circled two diodes in blue. these are actually on the top of the board. Check them for shorts. And I've circled the primary of TM801 in white. Check the resistance between those pins.
                                  PlainBill
                                    Im just wondering something, do you want me to Check all the pins of MC33067P with the capacitor or not ? In the DC or AC range ?
                                    For the diode, to test it for shorts, do I use the multimeter in the diode mode?
                                      Sorry, set your DMM to the 20 Volt DC range; the capacitor will not be necessary.
                                      To check the diodes use the 200 ohms range. It's unlikely the problem is the diodes or the transformer, but check the resistance across both diodes, and across the two pins of TM801.
                                      PlainBill
                                        Here are some more values with the monitor ON:
                                        Voltage between pins
                                        4 and 1: 5.05v
                                        4 and 2: 5.05v
                                        4 and 3: 2.54v
                                        4 and 5: 5.08v
                                        4 and 6: 0.07v
                                        4 and 7: 0.07v
                                        4 and 8: 5.04v
                                        4 and 9: 14.60v
                                        4 and 10: 0v
                                        4 and 11: 0.19v
                                        4 and 12: 14.06v
                                        4 and 13: 0v
                                        4 and 14: 0.27v
                                        4 and 15: 15.06v
                                        4 and 16: 5.04v
                                        For the resistors, transformer and diode I unplugged the monitor
                                        TM801: 0.8 ohm
                                        Diode DM804: 111.8 ohms
                                        Diode DM808: 111.7 ohms
                                        for the resistor (flat type) can you confirm it's the black one with the value on it ? My DMM read 5 ohms but the value on it seems to be 487 ??
                                        The cap (brown ?) is very small and doesn't seems to be damaged but it's very difficult to say !
                                          4 and 1: 5.05v
                                          4 and 2: 5.05v
                                          4 and 3: 2.54v
                                          4 and 5: 5.08v
                                          4 and 6: 0.07v
                                          4 and 7: 0.07v
                                          4 and 8: 5.04v
                                          4 and 9: 14.60v
                                          4 and 10: 0v
                                          4 and 11: 0.19v
                                          4 and 12: 14.06v
                                          4 and 13: 0v
                                          4 and 14: 0.27v
                                          4 and 15: 15.06v
                                          4 and 16: 5.04v
                                          TM801: 0.8 ohm
                                          Well, the readings on the diodes and transformer make sense. By any chance is the code on the resistor 4R7, not 487?
                                          A quick sidebar. The numbers on one of these resistors are usually vvm. vv represents the value digits, m is the number of zeros that follow the two value digits. A 3.3K resistor would be labeled 332, or 3300 ohms. A 2.2 Megohm resistor would be 225, or 2,200,000 ohms. A resistor labeled 487 would be 480,000,000 - which is a VERY high resistance AND not a standard value.
                                          The standard markings cannot represent a resistance of less than 10 ohms (100), so a slightly different method is used. A 6.8 ohm resistor is labeled 6R8, and a 4.7 ohm is labeled 4R7, which looks a LOT like 487 and measures 4.7 ohms (or 5 ohms).
                                          NOW lets get back to the IC. the voltages you got , and what they mean
                                          4 and 1: 5.05v Oscillator charge
                                          4 and 2: 5.05v Oscillator return
                                          4 and 3: 2.54v Oscillator control current
                                          4 and 5: 5.08v 5.1 V reference
                                          4 and 6: 0.07v Error amp out
                                          4 and 7: 0.07v Error amp - in
                                          4 and 8: 5.04v Error amp + in
                                          4 and 9: 14.60v Enable adj.
                                          4 and 10: 0v Fault input
                                          4 and 11: 0.19v Soft start
                                          4 and 12: 14.06v B output
                                          4 and 13: 0v Gnd
                                          4 and 14: 0.27v A Output
                                          4 and 15: 15.06v Vcc
                                          4 and 16: 5.04v One shot RC
                                          NOW, some voltages seem to indicate problems. From pins 1 and 2 I would suspect the oscillator is not running. Pins 3 and 5 look normal. 6, 7, and 8 also look like part of the circuit is disabled. 9 and 10 look good. 11 does not look reasonable - it should be higher. 12, 13, 14, and 15 look normal, whole 16 looks like it is waiting for something to happen.
                                          Most of these unusual voltage seem to originate inside the IC. The one that stands out is pin 11. The application schematic shows only a cap on that pin, but the power supply has two extra components. I've circled them in orange in the attached picture.
                                          Would you measure the resistance between the pins of these (transistors? diodes?)? For each one, number the pins 1, 2, and 3. Measure the resistance 1 to 2, 1 to 3, and 2 to 3. Also, there seem to be letters on the top of each. What are the letters?
                                          PlainBill
