Re: Lead-free solder and tin whiskers: Older than you think
^ It's true, sleeve bearing fans do have better shock resistance due to a larger impact area than the contact surfaces of a few bearings that will deform if the force is great enough, and ball bearing fans last longer primarily due to use of grease rather than oil that dissipates over time. Relube a sleeve bearing fan before it gets dry and the lifespan is usually longer than other components in the system so the issue becomes irrelevant unless the fan is to be reused.
It's not thermal cycling that wears sleeve bearings as much as the mechanical abrasion of starting and the high temperatures reached thinning and drying out the oil. It's a bit of an apples:oranges situation as HDDs are made to be reliable as possible within a reasonable budget while (most) sleeve bearing fans are made as cheaply as possible... budget construction includes low QC on whether they are balanced and no balancing attempt made later, and they'll use a poor quality oil lubricant to save fractions of a cent in build cost, and no oil reservoir to save 2 cents. Industrial fans tend to have at least a felt oil reservoir, if not also an oil fill hole or even an oil pump if a large enough fan.
To be clear there are high quality sleeve bearing fans, and I prefer them for a desktop PC where you have to listen to it running but on my file server that I only check on a few times a year, dual ball bearing fans are the only type I use.
