I have a few of these motherboards that were removed from ACER AM1640 mini-towers. The boards are made by MSI and are socket 775 with NVidia chipset. All boards either show no BIOS Codes or show D4.
On one board, I replaced a slightly bulging OST 6.3v 1000uf cap near the ram slots, and this was sufficient for the board to boot. The board would go into kernel panic as soon as it tried to access the hard disk. Similarly it would freeze if trying to read OS from a USB stick. This was after it had loaded the Ubuntu 10.4 OS using CDROM and IDE Drive.
I took another of these boards and replaced all the OST and Teapo caps with Panasonic and Nichicon and still no dice.
I am suspicious about the NVidia chipset.
Do these benefit from reflow, and if so do you use a heat sensor and thermometer to judge the heat coming from the heatgun? Do you apply the heat to the front or back of the chipset?
Suggestions welcome, thanks
