Hello, I'm a newby. I read a lot of post on the forum to search a case similar to mine, but nothing found to solve my problem.
I have a Sharp LC-37x20e. I think I have a problem with power supply unit rdenca230wjqz (DPS-240CP) by delta electronics.
If I leave tv unplugged from power for 1 day, then I plug it into the AC, the tv starts regularly (green led) and images, but after 1 minutes it shutdowns. No lamps, no messages, no standy-led after shutdown.
If I unplug power cord for a while, then reconnect, the tv starts (I see green led), but now it shutdowns after few seconds.
I downloaded service manual for this model and I tried to understand something.
So I tried so umount power board from TV and make some tests. I cannot see any bad capacitor, so I tried to perform something other.
In my tests, first I plug the power cord. I use my digital multimeter to read voltages on connectors.
On PD connector (see image in detail) I can read (using as ground the holes for screws at corners)
pin1 - NC -> 0V
pin2 - NC -> 0V
pin3 - NC -> 0V
pin4 - PS_ON -> 0V
pin5 - AC_DET -> 3.3V
pin6 - PNL_POW -> 0V
pin7 - SGND -> 0V
pin8 - BU5V -> 5V
pin9 - SGND -> 0V
pin10 - SGND -> 0V
pin11 - UR15V -> 0V
pin12 - UR15V -> 0V
I also read 0V on other pin connector at example INV60, UR12V etc. I understood it is normal because the power board is in standby mode. So I tried to connect 3.3V to PS_ON (it should be power on the board).
After that, I can see voltages UR15V, INV60, UR12V etc, but only for few seconds. Then they go to zero V. I think I have a power board problem, because I got same problem when it is attached to tv, and when power board is standalone.
I also tried to replace some components: D7121, D7918, C7150, C7151, C7152..
I think the my problem is due to a component malfunction (it goes only for few seconds) but I'm unable to understand where could be this component.. May someone give me some help please?
thank you very much.
Claudio
pin1 - NC -> 0V
pin2 - NC -> 0V
pin3 - NC -> 0V
pin4 - PS_ON -> 0V
pin7 - SGND -> 0V
pin8 - BU5V -> 5V
pin9 - SGND -> 0V
pin10 - SGND -> 0V
pin11 - UR15V -> 0V
pin12 - UR15V -> 0V
Claudio
