It's a Galaxy GeForce 7950 AGP video card. Two of the caps are bloated. both are 470uF 16v. There are some other FZ which look OK, but I'll relace them too. 3 other 470uF 16v, 2 16v 220uF and 5 6.3v 1500uF. I'll post some pics later. I'll probably use Rubycon MBZ or somthing similar to replace them.
Another video card with Sacon FZ
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProTags: None
Re: Another video card with Sacon FZ
Re-capped it (finally). I replaced the 3 larger 470uF 16V with Sanyo SEPC Polys and everything else with Rubycon MBZ. It works good enough to get into windows but I haven't tested it beyond that.I love putting bad caps and flat batteries in fire and watching them explode!!
NNNNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOO!
I accidentally bumped the card while it was running. Now it's fried (won't even POST).
Last edited by c_hegge; 01-12-2010, 02:28 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by ratdude747they go off like a firecracker, guts are spewed everywhere, nasty to clean up.I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by c_heggeI accidentally bumped the card while it was running. Now it's fried (won't even POST).
Could still be repairable.
Originally posted by ddscentralI have a non-working PC with a bad video card, a Club3D GF6600LE with Purple Sacon FZ (with K vents, not fake-poly).
It was just a small bump, nothing knocked off, shorted, etc. I suspect it may have caused an arc in the AGP slot (a bit like if I had tried to hot-swap the card). It's definately dead. I tried it in another motherboard and it didn't work there either.I love putting bad caps and flat batteries in fire and watching them explode!!
My DMM died, so I have no idea whether or not the caps are getting any voltage. I'll try re-soldering the joints, although I doubt if that will fix it.I love putting bad caps and flat batteries in fire and watching them explode!!
Re-soldering makes no difference (as I thought).I love putting bad caps and flat batteries in fire and watching them explode!!
Wasn't implying a cold joint. Meant that you could (simply) be looking at a bad transistor/diode/FET that may prove an easy fix. DMM problems aside, if the voltages are missing, that would be where I would start looking.
Hopefully the GPU is ok.veritas odium parit
I realised that you weren't suggesting a bad joint, just thought I would try it anyway. I'll have to get a new DMM before I can test for missing voltages.I love putting bad caps and flat batteries in fire and watching them explode!!
