Backlight problem on viewSonic VP171b
    Re: Backlight problem on viewSonic VP171b
    I have the same problem as previous posts, one second delay and then the screen goes black. It looks like I have a shorted transistor (Q5), but I can't identify it. The transistors Q3, Q4, Q5, and Q6 are all the same. They are very small and the only markings on them is "DK" on one line and "QN" underneath it.
    Can anyone identify these transistors?
      They are 2SC4672, the details are here.
      PlainBill
        I replaced Q5 and Q6 and that did the trick. For $5 total it's like brad new. Thanks PlainBill !!
          My monitor worked for about 2 weeks then it went blank again. Q5 and Q6 blew again. I replaced them and the monitor worked for about 10 seconds and then they blew again. Do you know what is causing these transistors to blow?
            In post #11, I'm fairly sure PlainBill is referring to the Benq boards where the C5707s short because of dodgy/poor soldering on the inverter transformers.
            Maybe resolder/reflow yours and see.
            --- begin sig file ---
            --- end sig file ---
              There are several causes of the transistors blowing. In addition to the transformers that retiredcaps mentioned, check the timing caps on the inverter (the large blue film cap next to each transformer). Also check for cracked solder joints on the inductor.
              PlainBill
