hi
i came across a couple 19" cheep lcd tv's both exactly the same and both with electronic problems. i had no use for tv's so i wonted to make them monitors, on ebay you can buy controller board and lcd inverters. so i bought two and they worked out great Except after a mount or two they started flashing when you turn them on, one did it first so i contacted the company i bought it from and they sent me a new lcd inverter. i installed it and now the other one is starting to do the same thing. so my though is each inverter has 2x 220uf 25v 105c caps on them and i'd like to replace them.
controller board are 12v
the new lcd inverter has two shcon caps witch state right on them low esr but i can't find shcon caps listed anywhere.
the lcd inverter that i have out that blinked has hy 220uf 25v lesr 105c
i need a good cap 220uf 25v lesr 105c
i was looking at these but they don't say low esr on them
Rubycon ZL 25v 220uF -40 to 105C 8X11.5mm p# 25ZL220M8X11.5
Rubycon ZLG 25v 220uF -40 to 105C 8X11.5mm p# 25ZLG220M8X11.5
i have two caps here marked with an m in a box marked 220uf 25v 105c FM
who makes the caps marked with an (m in a box)?
