White screen on a Samsung 225BW monitor
    Hello
    I had a flickering problem with my monitor and I changed the capacitor.
    Unfortunaly, since I retry- it, I got a white screen. No image at all, even with no cable, I can't have an image of the setup screen
    All capacitors where changed. No bad solder, no reversed capacitors, don't see any solder jump that could cause a short
    Initially, I had replaced (C301, C302) two 680UF by 1000uf. Could this as caused the problem. I did replaced the old 680uf but the problem remain.
    I did check a fuse F301 on the power board and it is OK
    Now, what else could I check?. Any voltage measurement
    Any info appreciated
    Martin
    Re: White screen on a Samsung 225BW monitor
    Recheck ribbon connection from main board to screen
      If original caps were 680uf I would of not replaced them with 1000uf you but can go up on the voltage
