bad neutral on new house
    Re: bad neutral on new house
    That must've been an aw-fuck moment. Did you get a measurement?
    I forgot the smiley
      I forgot the smiley
      measurement? on the pain scale i give it a 4. on a voltage scale it got about 135v.
      Follow the white rabbit.
        Considering it's a mains feed... Jesus, glad it didn't knock your dick in the dirt.
          +1 however there is a hole in the fence.
            So glad we take health and safety seriously Down Under (at 230V AC/415V at pole)...
              The circut breakers plug on the panel's buss . If they fall out when you take the cover off , there some major problems with the panel . If the o.p. of this thread knows how to use a volt meter then he/she could check the voltage between the ground and the neutral at the panel . If there is a voltage between the ground and neutral , then the problem is before it gets to that panel .
