Hey all.
This stick is a bit odd - you plug it in, it appears as a virtual CD ROM device with the drivers on. You install the drivers, and right click->eject the device. It then disconnects, and then reconnects as the actual WiFi stick and runs normally.
I'd like to make it so that you don't need to do that, and it just functions as a normal stick.
Tried shorting various things on the board with no luck. Nothing on the board heats up in CD ROM mode, the two Atheros chips heat up once it's a normal stick.
Very hi-res pictures of the PCB are here: http://wikidevi.com/wiki/Netgear_WNDA3200
On board there's an MX25L6445E flash chip and an ST 24C32WP.
I'm guessing I'd need to remove or flash the MX25L6445E?
Cheers!
Cheers!
