Sound card headers
    Sound card headers
    this will sound dumb...
    but i may be buying a sound-less mobo for a system with fron sound headers (headphone/mic).
    it is of the "ac 97" type:
    (not my pic)
    What I wonder is if there were ever any decent PCI sound cards with the conenction for such header... and if so, what model(s)?
    even better, if somebody (US/CA preferred) had one they were wanting to sell/trade, that would work too.
    sigpic
    (Insert witty quote here)
    Re: Sound card headers
    I don't understand what you really want.
    That connector is for an onboard sound chip to output stereo sound and take in microphone from jacks usually mounted on the case.
    It's unlikely you're going to find a sound card with those connectors because it's a an onboard sound/CODEC specific thing - a sound card would have processor and all jacks on the bracket.
    So I don't get what you want to do... do you want to connect the jacks in the case to a standalone sound card somehow, because the motherboard has no sound at all?
    If so, the pinout is easy enough:
    The one on the right is the old AC'97 layout, which is probably what the case connectors were designed for.
    Get two of these :
    http://www.monoprice.com/products/pr...seq=1&format=2
    and two of these
    Plug one jack in the back of the sound card, cut the other end and solder the wires to the wires from the case connector.
      Get two of these :
      and two of these
      it was the AC 97
      copied the wrong pic... I forgot that there was a similar HD on.
      the board has no sound at all... the chipset has it, but the board does not (blame supermicro)
      I would rather do this elegantly, as I have a hatred for inside to outside kluges like you suggested...
      I Have not bought the board yet... but it is from a "buddy" around here (you know who you are) and he gave me a pretty decent offer...
      the board is a supermicro x5DAL-tg2
      I'll do some searching and see... IIRC i once saw a card with it... I bet there has to be an OEM who used one (like the SB Live! cards with dell headphone headers)
      sigpic
        Apparently this one did have the connector:
        http://www.newegg.com/Product/Produc...82E16829156005
        but it's about 120$ new.
        This one looks like it has the place for a 10pin header but you have no guarantee that's really ac'97 or that the traces are there
        http://www.newegg.com/Product/Produc...82E16829111003
        There are some cheaper Startech cards that have the header but on one of the cards it's silkscreen-ed "GAME1" by the connector. But the Diamond card above HAS the game connector AND the header holes.
        This one has both: http://www.newegg.com/Product/Produc...82E16829265001
          I have a cheapo card that had the connector silkscreened... ages ago I added the pins to make it a header... it didn't work, but I might have gotten it upside down.
          it is one of these in green (recapped too):
          http://uk.eetnordic.com/product.aspx...RD-5.1-CHANNEL
          sigpic
            It is probably also missing some small surface mounted components.
              yeah, the header is no good... tested it, as soon as I plugged in my headphones, it shorted soemthign because the system did a hard reboot.
              I see this may be an uphill battle... there were plenty of cards that had the HD header but AC97 is looking bleak... I assume the MX_Link On my old diamond mx300 wouldn't be of use?
              sigpic
                its out of stock, but this is the cheapest one I can find
                http://www.newegg.com/Product/Produc...82E16829132020
                  Good job. Manual says it will do either jack.
                  looks like a good card too
                  maybe I can snare one on ebay...
                  ebay's cheapest is $30 shipped:
                  http://www.ebay.com/itm/ASUS-XONAR-D...item3cc321759a
                  sigpic
                    found why that port failed
                    look at this:
                    http://www.newegg.com/Product/Produc...82E16829265002
                    it has the same chip (or similar) and the port is installed.. it is listed as optical in/out
                    no wonder....
                    sigpic
                      Some computers with this audio header may have a BIOS option of selecting "AC97" or "Azalia".
                        this one doesn't... there is no audio coonetions on the PCB. not even silkscreened:
                        sigpic
                          It looks Iike I will do the asus xonar DG if I get the board... I may use a different card initally and hold out a bit to see if I can snare one for cheap...
                          they also seem to have decent linux support from what I have seen...
                          sigpic
                            problem solved!
                            another BCN buddy (you too know who you are) has oen of these:
                            http://www.facebook.com/l.php?u=http...F9&h=6AQEX0wju
                            (recapped, too)
                            if I get the board, I'll buy it off him...
                            sigpic
