Re: Potenciometer for fan regulator
The Zener is for regulating the output voltage if the input voltage fluctuates, nothing to do with limiting current, but if you need 12v out (input has to be higher than 12V, 15V will be good) the zener voltage will have to be 0.6v higher than the require output, I pick 1K base on beta of 100 on the transistor but I will not run dead short between Base and Collector. Voltage output will always be 0.6V less than the Base to Ground voltage because it is Emitter follower circuit.
Motor start up current can be high, so if 1A base current can damage the EB junction, not good practice to run transistor that way.
Yes, cap is 0.1uF.
Yes, cap is 0.1uF.
