Re: LG Flatron W1934S
OK Let us start that again
All the time it was on mean all the time the screen had some backlight on it... when it disappeared I turned off the monitor. Guess it last one minute.Should I leave it plugged longer?
Set up your PC with the vivid picture - check that if left this will stay on for 10 mins.
Start again - Set up your PC with the vivid picture then connect the W1934S and switch it on.
You say it will then come on, flash something, go black,come back on for up to one minute then go black.
Is that correct?
You must then just leave it as it is -do not switch anything off or unplug anything.
THEN try the torch test.
It may be that that is what you did but it has lost something in translation.
Also I dont think you answered this question:
does the power light led come on, stay on, flash, change colour.
Is that correct?
