I have an older phillips lcd that has a strange problem. When I first plug it in after it has been sitting a while, it will not turn on. No green /orange led...nothing. I opened it up and all the caps look ok, and i found out that if I have the AC plugged in and disconnect and reconnect the power cable from the power supply to the board with the display connections, it will start right up. I can even power it off and on normally no problem. However, the problem shows up again if I leave the the LCD unplugged for a while. Any ideas?
Thanks!
Thanks!
