Dell E196FPf
    Re: Dell E196FPf
    Originally posted by Rtech View Post
    R856 is 15Ω R861 is 470Ω...cannot find the other resistor, check the number...also I am away on holiday today,so hopefully someone will help with other values if necessary.
    thanks for the reply,
    Here a pic of a burnt parts... the number hmmm
    btw.. Thanks a lot for the help.
      Re: Dell E196FPf
      Maybe see here?
      http://www.google.co.uk/url?sa=t&rct...73612305,d.d2s
        Re: Dell E196FPf
        Originally posted by smason View Post
        Hi all, this will be my first attempt at repairing an LCD monitor. I haven't done much repair work in a long time, so I'm dusting off my gear and hoping for the best... Monitor is a Dell E196FPf no backlight. Image is visible on the monitor with a flashlight so I suspect just the inverter, or maybe a bad lamp, though none of the 4 come on at all, even at power up... 2 caps in the inverter section are bulged and have relatively high ESR (2 ohms) other than that no obvious visible signs.
        I have a similar situation to smason in the OP quoted above. I have 3 E196FPf monitors and all show the same symptom - the power indicator shows green and stays green - no blinking and no amber. After a quick web search that turned up this thread, I decided to disassemble one - sure enough, it has 2 bulging caps in the inverter section shown in smason's close-up pics.
        We've done a bit of minor cap repair to some older model car dashboards, but nothing really like a computer board. Before I dive in, any pointers - things to do, not do, watch out for, buy, etc.?
        Thanks in advance for any help.
          Re: Dell E196FPf
          I'm caught up on other projects and have replacement caps for these monitor boards in hand. Any advice on how to proceed? As I mentioned above, we have some soldering/cap replacement experience, but it was only on car dashboards about 10-15 years old. We've never tackled anything complicated like a computer motherboard. We do have a couple of different soldering irons but, for the most part, we're starting from scratch in both supplies and experience.
          Thanks in advance for any advice - or pointers to instructions we could use.
            Re: Dell E196FPf
            I just ran across something that reminded me that I hadn't checked this in a while. Before we start the repair process, what should we know?
              Re: Dell E196FPf
              Ok there is awhole forum devoted to this amongst other things
              Read this https://www.badcaps.net/forum/showthread.php?t=31448
              There is some useful ideas and a youtube video which leads to a whole series of videos on
              soldering.
              My tip - 40 watt iron Leaded solder with flux. more flux. if you are working in a cold place pre heat the board gently with a hair dryer or very very gently with a hot air gun
