MS-N0141 ver-2.1
msi mini MS-N014 bios needed
Re: msi mini MS-N014 bios needed
Whats it for the U130 ? or the MSI Wind U135 DX..
Check there site make sure you download and flash it with the correct one
for your chip
This is for the 'MSI Wind U135 DX'
http://www.msi.com/support/nb/U135DX.html#down-biosLast edited by calos2015; 03-01-2015, 06:28 PM.
Re: msi mini MS-N014 Help Not Working
Originally posted by ranjanlaptop View PostMS-N0141 ver-2.1
I have a Laptop with the motherboard model MS-N0141 V.21.
The flaw is that it does not give video.
When connecting the charger, sometimes it does not do anything, other times it turns on, but a buzz is heard.
You connect a pendrive and when you do the ignition process, you can see the flash pendriver light.
The failure occurs with the RAM module installed, as if it does not have it, (internal RAM on board)
The rest does not do anything else, connect a USB keyboard and do not turn on the lights of it.
I did the test to connect the battery and the red LED flashes. (Loading process)
Previously, check the voltages and the voltages of 3.3v, 5v, 19v, 1.0, 1.5, 0.70vdc are correct.
With the oscilloscope, there is signal activity in the BIOS terminals.
I did not find any pulse activity on the keyboard connector, I think there should be some signal on those pins. Near the chip. "ENE" However in some pins I found pulse trains.
Can you help me in what may be the problem with that plate?
Thank you
Español / Lenguage Natal.
Hola a todos.
Tengo una Laptop con la tarjeta madre modelo MS-N0141 V.21.
La falla es que no da video.
Al conectar el cargador, a veces no hace nada, otras veces enciende, pero se escucha un zumbido.
Le conecte un pendrive y cuando hace el proceso de encendido, se observa la luz del pendriver destellar.
La falla se produce con el módulo de memoria RAM instalado, como si no lo tiene, (RAM interna en placa)
Del resto no hace más nada, conecte un teclado USB y no se encienden las luces del mismo.
Hice la prueba de conectar la batería y se enciende el led rojo destellando. (Proceso de carga)
Previamente, verifique los voltajes y están correctos los voltajes de 3.3v, 5v, 19v, 1,0, 1,5, 0,70vdc.
Con el osciloscopio, hay actividad de señal en los terminales del BIOS.
No encontré ninguna actividad de pulsos en el conector de teclado, pienso que debería haber alguna señal en esos pines. Cerca del chip. “ENE” Sin embargo en algunos pines encontré trenes de pulsos.
¿Pueden ayudarme en que puede ser el problema de dicha placa?
Gracias
