Hello, I have a Dell N5010 that has a shorted area on both sides of the board in the same (reciprocal) area. The section in the schematic belongs to the battery charger management. All the components in the two areas are shorted. I am not sure what is the best way to proceed. I was going to remove components one by one to see if the short disappears. I have already removed the buck controller (PU4501) as you can see in the picture but the short remains. I thought the next suspects would be the mosfets (PU4504/5/3) and my plan was to remove them one by one and test for the short at each removal. Is this what you guys would do? Any suggestions would be appreciated. I don't have an oscilloscope and wouldn't know how to use one anyway. I was going to bin the board and buy a new one but the costs are too much.
DELL N5010 shorted area
Re: DELL N5010 shorted area
Originally posted by khaahk View PostSo you got 0 ohms to gnd from all 3 points?
At Point 1 =2 Caps (both read the same) = 0.3 ohms and 7.6 ohms at other end
At Point 2 =Cap = 0.3 and 2.9 ohms
At Point 3 =Mosfet:
pins1, 2 and 3 =7.6 ohms
pin 4=134.9 ohms
pins 5,6,7,8 =2.8 ohms
My DMM is set at the 200 ohm scale and shows 0.4 ohms when the probes are touched together.
Continuity meter gives a beep for everything in the area to ground. I was thinking there is a component within the circle(s) that is causing the entire circuit to show as shorted. My first guess was the buck converter but its removal didn't help. Appreciate your interest Khaahk. A palindrome!Last edited by sparker1; 01-30-2015, 02:04 AM.
OK. I removed both mosfets and the short seems to have gone. Here are the measurements with the mosfets removed:
Point1 (2 caps) = 0.3 and infinity
Point 2 (cap) = 0.3 and infinity
Point 4 (mosfet) = pin4 is 0.207Mohm all other pins infinity.
I'll replace those two mosfets and the buck converter and see what happens.
Originally posted by khaahk View PostNo voltage measurements? Giving up a little too easy...
PU4502 voltages on all pins?
+3.3V_ALW_2 present?
+3.3V_ALW present?
+5V_ALW present?
Pin 2 and 22 voltage on PU4501?
VREG 3 and 5 its the output on PU4601
P.S. Don`t forget ACOK on pin 13 ; That could be a give away if its not ok thereLast edited by dj_ricoh; 01-31-2015, 03:05 AM.Just cook it! It's already broken.
it is very difficult to point out the short component on main power line because a lot of component are mount on that line and every will be show short so a simple way which i used to inject external power low voltage with high ampere so the short component will be burn or heat up so it is simple way which i rectify many laptop.
Originally posted by sparker1 View PostOK. I removed both mosfets and the short seems to have gone. Here are the measurements with the mosfets removed:
The buck controller was replaced with a new one. The old mosfets were shorted drain to source and were replaced with a stock I had - some were new and some off scrap boards so I'm not sure how old they were but they tested OK. I did some voltage measurement on PU4601 (buck controller) voltages:
Pin 23 (pwgood)=2.59v
Pin 17 (5v)=3.27v
Pin 8 (3v)=0.0v
I don't know what to make of these readings.
Originally posted by sparker1 View PostThe buck controller was replaced with a new one. The old mosfets were shorted drain to source and were replaced with a stock I had - some were new and some off scrap boards so I'm not sure how old they were but they tested OK. I did some voltage measurement on PU4601 (buck controller) voltages:
Pin 17 (5v)=3.27v
Pin 8 (3v)=0.0v
take every pin!Just cook it! It's already broken.
